GordonHemi
- Jan 29, 2017
- 4
Hi folks, first post on here and in fact ever Trying to determine what the exact model # of my sterndrive engine is. Just got the boat given to me and anxious to get it fired up but need a coil and a few little parts. Cannot find anywhere on line where to find the engine ID tag tho. Valve covers and entire engine are just all blue. Casting number on block 460777 tells me its a 78-79 305. Hull number AMM21309M78G tells me the boat is a 1978 (Bell Boy Cuddy). The Drive ID tag says: model #981112 (found nothing on that) and serial #W165237 although I believe the bottom end has been replaced with a slightly newer one?? Stringer I guess..
Air cleaner has B175-37 & 162.041 72 stamped on it although that may just be for the air cleaner. Somebody said look down by the flywheel but i tried and it's pretty grimy down there. The boat has fresh water cooling on it which is nice. Not sure if that's after market or original though it seems old. Wondered if the missing info is hiding under there? Also found a number cast into Starboard riser which I think says 909215S which means nothing although its very close to some of the 1973&4 model numbers. No I don't have dyslexia ... All the model #'s seem to start w 99. Any help in the next few days would be much appreciated. Dying to find out the hp rating. The boat is called Sea Dog though so not expecting it to be as fast as my last boat Robalo 227. Best boat ever.
