zigbat
- Jul 14, 2016
- 62
1988 18' SeaSwirl Sierra Cuddy - OMC 2.3L Cobra
I was checking my bellows etc and when I was putting the drive back on I screwed up and broke the brass part on my shift cable..
So now I am looking to replace it, but the only number to be found on the cable is 3193R APR 2013 its stamped in the red outer casing..
on ebay I found
"Lower Shift Cable Assembly for OMC Cobra Sterndrive Replaces 987661"
it also says..
Replaces OMC 987661 (older part numbers 986654, 987498).
Complete kit including gasket set to repair mechanical lower shift cable on OMC Cobra Sterndrives 1986-1993.
Please compare part numbers.
This cable may not fit some late model 5.0L fuel injected engines, 2.3L OMC Ford engines, 5.7L OMC engines in 1987 or late model 5.8L engines (e.g. the 1993 5.8L).
Those applications may require a special cable.
Can anyone enlighten me on this...
With no part number to be found on the cable and I dont have a parts catalog and specific numbers are not in the Service Manual
and these suckers are over a yard note easy so I only wanna have to buy one
I am having some difficulty deciding what i want to do..
on ebay I found
it also says..
