bcollins47
- Sep 3, 2012
- 20
The boat started about a month ago when we put I put a battery charger on it. I assumed all I need to put was charge the battery. Once I charged the battery the engine won't turn over.... It doesn't even try to turn over. What I have done up to this point... Checked ignition with test light, checked to make sure boat was in neutral, checked kill switch, checked all the fuses I could find under dash. Looked for fuses in the engine compartment but couldn't find any. The gauges works and the volt gauge show 13 volts. It seem like some fuse or something is preventing it from turning over.
I can't seem to figure it out!!!!! ugh!
equipment :
1995 four winns 240 horizon
Engine 7.4l 74FEPHUB
Any help would be appreciated!!!!!!
Thanks,
Brent
equipment :
Thanks,
Brent
