Okay guys I am totally fried on this project that was given to me. I grew up skiing behind this great old boat but my dad let it sit for 10 years then decided to give it to me with some modifications that were never tested just installed arrggg.
Start with the first, old Mallory ignition with points replaced with Mallory upgrade to electronic: I have been reading here that I may need to change out some other points just to get it to go in gear, which I found out my dad had defeated the switch(don't know where) that doesn't allow you start in gear which it does now(not good).
Second, had to tear down outdrive due to water pump no longer working and shift cable was shot so replaced it with new one:
the problem with this is I can no longer get it in gear with it hooked to the lower unit or not. Attaching a few pictures with some descriptions and maybe someone can see what I have done wrong. I have worked on engines but this is definitely more confusing than I thought and a lot more seals still need to be replaced due to it sitting for way to long.
PLEASE HELP ANYONE, EVEN A NUMBER TO CALL
