I seem to remember you saying the corrosion was on the bellows connection at the transom mount
You probably need to be a bit more specific on what you want. Do you need a "transom plate" , OMC #0913826 TRANSOM PLATE?
Or do you need #0986977 GIMBAL HOUSING ?
Now having said that, The partnership started in the early 90's. since OMC had a LOT of DOG-Clutch Cobras still in the pipeline, they still offered them for the lower HP engines. The bigger ones (7.4, 7.5,8.2 ) got the interim Cone Clutch drive starting about 90...Then the SX's
The break point is when you see engine mounted raw water pumps. (If your raw water pump is drive mounted You have the NON Volvo drive)
The Volvo SX for the big block engines is different. I would suggest you call a Volvo dealer and ask them if there is a Volvo Transom plate that will fit your transom mount. I don't believe there is. You'll probably have to scrounge a transom plate or transom housing (if that's what you really need) from a wrecked boat or wrecking yard.
Your only other option other than welding etc, will probably be changing the transom mount and the drive to all Volvo (SX)
