Ok I replaced the shift wire down to the coils, and all the seals and gaskets and put it back together. I now have power on one wire at a time.
They ohm out at 5.2 ohms. Took it to the ramp because I am unsure how to run it with water in the driveway and it will still only shift into reverse. It does nothing when I shift into forward.
It has power at the connection just before it goes through the transom. I did put type C oil in it.
I believe the coil test ok, I read on here about a spring that can break and cause it not to work. Any ideas???
Thanks
