Troy Adams
- May 6, 2015
- 18
I've lost all spark, will not fire. Two weeks ago it r a n perfect. Then the following week I launched the boat, let it warm up. I proceeded through the no wake zone with no problem. When I attempted to throttle up it it ran like it was running out of fuel. Then I noticed the smell of unburnt gas, like the choke was stuck. It wasnt, so I pulled the boat out of the water. Since then I replaced the fuel pump, rebuilt the carb. Now it will barely idle,and chugs like it has performance cam. I checked the timing off the crank and it was kinda bouncing around. Between 6 and 12 degrees BTDC. I then changed the points condenser and coil. Now it won't even fire. The only thing left that can think is the resistor. From what I understand that's built into the wire harness. I'd hate to change that out. I hope someone can help. Thanks
