I have been researching and can not find a problem that resembles mine exactly. So i figured i would post.
1989 Sunbird Corsair 195
OMC 3.0L 4cyl
OMC Cobra Outdrive
I winterized my boat two years ago, and it sat all last year, never started once. I have since found my winterization techniques are not the best. First i chaged the oil and the filter. Then I pulled the water hoses on the engine, and then I puled the petcocks on the block. I then used muffs and antifreeze to introduce AF into the raw water system. Next I fogged the engine through the carburetor. At the end, I used the the fogger to kill the engine. Lastly i sprayed the fogger in the spark plug holes. I drained the out drive completely, and now i filled in this year before i started it.
That is the background, Now heres my problem... I started the boat, and started getting milkshake out of the valve cover breather (the hose that goes to the spark aresstor)
I shut it down immediate and pulled the dipstick. The stick showed WAY over full with the same consistency of a milkshake.
I drained the oil; I would estimate about 10 quarts of fluid came out of the pan.
I replaced the oil, and started. Let run for ~20 mins on muffs. The consistency was milky, not nearly as bad, but still far from good.
I replaced the oil and filter again, Ran for ~30 mins on muffs and the oil looks fine....
Every time I started, it appeared to be running fine
I can not understand or explain what is going on!? I do not have the tools or access to the tools to do a compression test, or leak down test. Every marina around me will not touch the boat because it is an OMC.
Whats my next steps? Any recommendations or thoughts are appreciated. Sorry for being long winded
OMC 3.0L 4cyl
OMC Cobra Outdrive
