Hi
I have my outdrive off the boat to replace the shift cable and water pump ........but I want to start the motor and make sure it is ok before I dump any more money into this .
I made 2 manifolds to bolt on to the intermediate housing sides where the water enters from the outdrive water pump anyone see a problem with me running the motor like this off the garden water hose ?
Just want to make sure everything is ok in the motor as it wasnt running when I got it and when I took the water pump out it was cracked .......thinking because the previous owner left the outdrive in the up position when he stored it for the winter.
Thanks
Sean
Thanks
Sean
