284Bullitt
- Sep 30, 2014
- 12
New at boating - bought a 1987 twin OMC 305 Amerosport. Replaced plus, coil, petronixs module, rotor, cap, and rebuilt carb. Checked over stroke switchs and connections.
Crusin at 2800 and heard what sounded like a large switch click - the engine faltered - took the engine down to about 800rpm and used the starboard enging to get home.
Engine has not restarted since that day - everything works as it should, good spark, fresh fuel & filters, no damage noted anywhere ! I turn the key and all it does is roll over - not a spit or sputter. Rechecked every thing including compression - lowest is 125 - highest 150 !
I heard about a resister wire in the key switch - how do I find and check that and what should I look for ?
They guy I bought the boat from seemed to be one who just added things where ever he wanted to. He added fish finder, gps and stereo all by just tapping into what ever he found . I cant find a wiring diagram for my boat so between being new and nothing to go on - I need help !
I live in up state NY and mechanics around here will only talk to you if you hang out $125/hour. One electrical repairman made three appointments and never showed.
Help !
Help !
