kokajohn;n10055189 I noticed some oil on the carport floor after about 8 hours said:
Howdy,
Welcome aboard.......Well, it's sort of difficult not to be a little snarky!
But I'd say you have a leak......... It depends on what kind of oil it is. Engine, power steering (if equipped), trim pump or drive oil (if it didn't really come out of the bilge drain).
If it's the engine or trim pump leaking, you'll need to clean the engine and everything in the engine compartment and start looking to see where it's leaking. It's not abnormal to have minor engine leaks in 30 year old engines.
I'll assume that you check your oil frequently and it's NOT using huge amounts of oil during normal running. You should fix any trim system leaks though. The trim pump reservoir doesn't hold all that much fluid.
Cheers,
Rick
