simbey1982
- Jul 2, 2013
- 16
Have a 120 OMC "iron duke" straight 4 engine with a Mercruiser Sterndrive
Just pulled the boat out for the first run of the year. Wouldn't start and had no spark, so I change the points and condenser (points gapped to .019). After some fiddling I finally get it to start, albeit a little rough. Put her on the water and it runs fine for an hour or so. Pull a tube and run around the lake. Then without warning the engine starts to have a sudden power loss. Engine sounds like its "bogging" down.
What i mean is I will accelerate to speed, then the rpms suddenly drop off and I lose all power until the engine dies. Starts right back up, It will idle and do low speed fine but once I start to give some throttle it will go for a few seconds then drop off. If I am quick enough and pull the throttle back before the engine winds down then it stays running.
Then after dying about 10 times the engine would not restart until I unhooked the throttle linkage and manually dumped fuel into the carburetor while turning it over. Then it started back up again enough to limp it to the dock.
Thoughts?
Cory
Thoughts?
Cory
