Fastinthepast
- Aug 9, 2015
- 9
Hello, thanks in advance for any help.
I have searched and read until my head hurts but cannot find the info I need. I have an 89 bay liner 5.8 Capri. I have unhooked the shift cable from the carb , removed the out drive and then removed the nut and bolt from the plastic guide. I also pulled the rubber liner that the cable is in out from the steering components and laid it out beside the engine for a straight shot to pull. Problem is it won't come out. I see what looks to be a brass nut if I raise the pivot housing that's connected to the cable, does that need to come off and if so is there a trick to removing it because a wrench really has no room.
