1990 Four Winns Candia 180, Cobra 4.3
After 2 yrs out of the water, I decided this summer it was going back in. Early struggles included bad gas and a dirty carb along with bad shift cable and suspect bellows (exhaust was ripped). I had the tank pumped, the carb serviced, and the shift cable and bellows done. My long term goal was to compound the exterior and replace some stained/ripped seat covers.
Then came the water. I noticed the bilge pump running for about 30 seconds after a WOT run on the water. Does not seem to leak when tied off in a slip. I pulled it on to the trailer and while still on the ramp (in the water) let it run in gear. It appear to be getting a leak at the top corner below the shift cable. Now, I had gone through the seven stages of grief regarding an impending transom replacement, but I thought I would post it here for further consideration. I had the drive serviced- bellows and shift cable (no water tube) as well as a new impeller but started to think that one of those could be the issue? The shift cable sits above the waterline, so I doubt it would be the culprit. Here's the thing...I have not observed it, but water intrusion seems to increase considerably with speed. I've not done the screw driver test to the transom, but I have given the drive a considerable tug and no flexing. I also (don't hate on me) caulked with 5200 any on the drive below the water line. Still have the same leak.
Any thoughts or am I just kidding myself and should be prepared to do a transom.?
