lil' beaver
- Mar 16, 2015
- 32
I'm at my wits end with my outboards. Going into this season I had 3 140 outboards omc outboards running. Half way through our boating season I have a total of 10 hours on the water and 3 outboards that need work. The 81' 140 rude had an overheat and I needed to replace the thermostats. Of course I broke a bolt when trying to remove the housing, now I need to remove the powerhead and get the bolt extracted.
I decided to put the '88 140 johnson on to finish the season. Got it out of storage, ran good on stand. It has been sitting so I installed a water pump kit, new stats, changed lower unit oil, rebuilt carbs and we are ready to go. Go to start it up and have no spark on any cyl. I mess with it for a little then decide to take it to the shop. Two weeks later and a bunch of parts thrown at it they can't figure it out. Luckily they replace my original parts and I only have to eat the labor cost.
Ok, I will put the 80' 140 johnson on and go from there. Get it out, run it, test everything, we a good. Install it on the boat, test run it on the lake, we are good. Go to pull it out of the water and the tilt wont work. Manually trim the motor and head home with my tail between my legs. Go to put fluid in it and can't get the fill screw out to save my life. Decided to swap trim units from the 81' 140 rude and the tilt ram pin is frozen and I can't remove it. Rant over.
We have been talking about getting a new motor for quite some time now but never really wanted to spend the money. I may be just frustrated right now but I'm real close to pulling the trigger on a new motor. We are going to loose most of our boating season. At what point do you just give up, bite the bullet, and go new?
