Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How long does it take gas to go bad?
  • How long does it take gas to go bad?
    I'm working on my own recipe for seafoam. So far what I've made smells the same...but that's the extent of my testing. I'm going to try it out in an old lawnmower engine to see how it cleans up the internals, but I want to test it's fuel stabilizing abilities. Aproximately how long does it take about a quart of gas to go bad?
    Re: How long does it take gas to go bad?
    One year? If that's true why would anyone bother with fuel stabilizer over the winter? Also am I correct in thinking it goes bad faster in smaller amounts? I'm thinking now of using only about a pint of gas...just to speed up the testing.
    • #3
      FWIIW, this summer I drew out about a pint of 87 octane gas into a clear jar for priming my carbuerator. I left it sit outside, with a cap screwed on, when I was done with it. After about a week, the gasoline turned cloudy. After about a month, the gas cleared up leaving a bit of curd settling out in the bottom of the jar. When it cleared it was a different hue than when it was freshly poured into the jar. I don't know what it means but it was a visual change in the gasoline. I ended up just pouring it back into the 5 gal lawnmower gas can.
      • #4
        According to Chevron, it looks like about one year in a tightly sealed container in a moderate environment.There's some excellent information here: http://www.chevron.com/prodserv/fuel...term_gasoline/
        • #5
          ZmOz Up until about 5 years ago, I never used anything when I stored my engine for the winter(5 Months). Never did have a problem with it in the spring. Never rebuilt the Carb or anything. Never used a decarb product. Still have the same little motor on my runabout going strong. It's an 89' Johnson 28 HP. So I have to wonder about all the additives we put in now days. But, like most, I do use Stabil and fog the motor every year before I put it up now. And I do decarb regularly, now. But, that's on my 91' 70 HP rude, not that it matters. Just a change in thinking or maybe reading these forums have changed the way I do things to preserve my motor. Then again, if I did nothing to it but run it every year and put it up in the fall until spring, like I used to, who knows....
          Rick
          "Boating is Life...All the rest is just Details"
          2007 Bentley 200 Cruise
          2007 Merc. 90 4 stroke
          • #6
            I'm with rickdb1boat on this one. There are 10s of 1000s of boats that are used each winter here in Florida and sit the rest of the year without stabil type additives. They start, run fine and don't wear out faster. Nothing happens to them. I've watched this happen for many years and it hasn't changed.
            • #7
              Alway used a stabilizer in my boats. Never a problem.Forgot to put stabilizer in the lawn mower and a motorcycle. When I took them out of storage 6 months later, the carburetors had plugged jets on both. Cleaning the carb on the lawnmower was a piece of cake. Cleaning 4 carbs on the bike was a lot of work. Stabilizer seems like a real good investment.Six months and I was in trouble. Varnish in the jets, crap in the float bowels. Charles
              • #8
                What's interesting is that my jug of STA-BIL says fuel deteriorates in 60 days, and that STA-BIL will last 12 months. Chevron says 12 months without stabilizer. Who knows?
                • #9
                  I agree with both extremes. I have observed more than once that if I leave an jerry can open for several weeks, the gas inside loses a lot of its volatility. Even hard to start a fire with it. I assume that the volatile component of the gas has slowly evaporated, leaving a higher concentration impure gas in the can (maybe the additives, or maybe gas breaksdown into more than one component - I don't know). I have also observed the drain lines in my outboard get clogged with a gummy substance if I leave any gas in the sagging portions of the lines after draining the carb bowls. On the other hand, I have left my tanks considerably full over the winter without stabilizer and drained it in the spring to use in lawn mowers and cars etc. There has never been a problem. It would appear to me that in large amounts, that is to say in containers that do not have a relatively large area to expose the gas to air, gas seems to last quite some time. The same is not true for smaller amounts.
                  • #10
                    I would assume that 2-stroke pre-mix would have different characteristics?Used outboard pre-mix in a lawn mower for two summers (same tank) before it gummed up so bad you couldn't turn the crankshaft. Trashed the mower & hired a yard man. That was 14 years ago & I haven't mowed a lawn since. "Sorry, hon, no lawn mower!"
                    It's all about the tools.
                    "If the ocean is glass flat and the sun is shining, you open up the special memory compartment of your brain and start recording the smells, sounds, sights and feelings." -- Philster
                    "Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
                    • #11
                      I quit draining ob carbs for storage...in my experience all it did was speed up the sludging process and create carb problems. I learned this by mistake when I was out of the country for a year and didn't get a chance to run the carbs dry on 2 motors before I left. I came back and the the carbs were fine (before that I ran the carbs dry every time I used an outboard, now I never run a carb dry). For the next few years I left fuel in the carbs for 6-12 mos storage and still pulled the carbs down to check them. That was in 1974, I still have the same two kickers...which only get used once or twice a year to make sure they work. I don't use Stabil either, only because I haven't seen the need. This isn't saying Stabil doesn't work but I don't believe we have as big a problem as advertising leads us to believe. If it was that "critical" the FAA would dictate stabil type additive for airplane engines and the FAA makes mountains out of mole hills. Airplanes sit more than boats do and NOBODY uses stabil in their airplanes.
                      • #12
                        Hmmm...interesting...guess I won't waste my time with a test to see how long the gas lasts. I've never used stabilizer over the winter either, but until this year the only thing I had that sat all winter was the lawnmower.
                        • #13
                          Some of the problem with stale gas is associated with being left open to evaporate. Rememeber gasoline isn't a pure chemical like say toluene. It is a compound of many toluene, xylene, pentene, blah, blah, etc. Some of these are more volatile than others. Some of the heavy molecular weight stuff will polymerize (varnish) if some of the others go away (evaporate). Condensation in the air in the tank can cloud the gas and precipitate stuff. Some of the additives will oxidize in the air. Gas left in a full tank tightly sealed will last longer than gas left in a 1/4 full tank, and longer that a tank left with the top off.By the way piston engine airplane fuel is not gasoline, it is a different brew. It looks different and smells different. And every time they go to crank it up they manually check the tank for water.Anybody who makes something like Stabil is going to exaggerate the case for its use. They're not lying so much as perhaps overemphasizing the potential problem.One of the reasons I like oil injection on my Suzuki (which doesn't mix until the intake manifold) is when the gas evaporates it doesn't leave sticky oil crud everywhere which is half the problem with old premix.
                          • #14
                            jimd,Airplanes have just as big storage problem as boat motors...probably worse. I don't know what the diffence is between aviation and car gas is other than higher octane and lots of lead. Either runs in cars or planes. Many experimental plane owners use car gas in their Cont & Lyc engines with lasting TBO results. And the grass roots drag racers come down to the airport to buy the higher octane fuel for street racing. The only problem I've heard is vapor lock in aircraft engines when using auto gas.
                            • #15
                              Air craft engines during pre-flight have the floatbowl partially drained to get rid of crap. No the same as outboards. nevjb
                              Back to Top
