Yes you can add temp senders -- one on each head. You then add a switch that allows you select left or right head. You cannot monitor both at the same time unless you add two gauges. You essentially end up with cylinder head temperature gauges instead of water temperature but they are close enough anyway that the difference is a thin layer of metal (the head).
