HI, does any one have a good way to clean sludge out of an outboard gas tank.? thank you
F freddie1944 Cadet Joined Apr 26, 2015 Messages 19 May 6, 2015 #1 HI, does any one have a good way to clean sludge out of an outboard gas tank.? thank you
R robert graham Admiral Joined Apr 16, 2009 Messages 6,908 May 6, 2015 #2 If it's a portable tank and you can remove it from the boat you can put several handfuls of gravel and some solvent like Berryman's B-12 and shake the tank until sludge is removed, then rinse and dry....
H hardwater fisherman Lieutenant Commander Joined Mar 19, 2010 Messages 1,725 May 6, 2015 #3 Is it plastic or metal?
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 47,561 May 6, 2015 #4 POR 15 marine clean also works.
