zippy83
- Jan 1, 2013
- 488
Hi all,
When I was changing my water pump I put everything together like it was. Later I saw a post here and someone said that the drive shaft needs to be greased. Do I need to take it apart again and get that done?
Also this was my first time replacing a water pump. I got all parts replaced and when I was putting the housing onto the impeler I was turning the drive shaft clockwise. I was also told to put some dish soap inside the housing and on the impeler. I did not try to turn the outboard on. will that be a problem if I wait untill spring?
Thanks
Zipp
Thanks
Zipp
