The oil ratio argument goes something like this....
Most engines don't need 50:1 unless they are at full noise, where maximum stress is.
Most oil injected engines usually run mid range in the 80 to 100:1 area.
The early Merc DFI engines ran 400:1 at idle and very low speeds.
For a while some Johnson/Evinrudes and some of the Jap engines recommended 100:1.
All of these work well... The problems come when you store the engine. At 50:1 there is plenty of oil in the engine to protect the metal surfaces and bearings. But when you get down to the 100:1 it starts being a little thin. At 400:1 it's definitely too thin. Merc's answer to that problem is to shoot a wad of oil into the engine as it's shutting down.
So, what's the best ratio? Based on the need for oil in the engine to protect during 'non-use' as much as use, I'd stick with 50:1....
Chris.......
