Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Mixing synthetic blend two-cycle oil and non-synthetic oil
  • Mixing synthetic blend two-cycle oil and non-synthetic oil
    I have a 1994 60HP Johnson outboard motor. It's a 2-stroke engine with an oil injection reservoir. I've been using non-synthetic Evinrude/Johnson 2 stroke outboard oil that meets (or exceeds) the TCW-3 standards. I've seen the Evinrude Ficht RAM injection synthetic blend 2 cycle oil and have heard that it's a cleaner oil that leaves less carbon deposits in the cylinders. First of all, is it really a better oil to be using? If so and I start using this new synthetic blend oil, do I have to empty the non-synthetic oil from the oil injection reservoir or can I add it to the non-synthetic oil already in the reservoir?
    Re: Mixing synthetic blend two-cycle oil and non-synthetic oil
    There should be no worries mixing the two. Suggest you run it low before switching.Opnions on oil vary. Personally I prefer a well known brand, mineral, oil and have no problems.
    • #3
      The FICHT Ram synthetic blend oil will mix OK with any other TC-W3 lube. You will find that it smokes less and that you will have a cleaner running motor. Let your oil tank get close to empty, then add the new oil to it.
      Back to Top
