beckoning
- Dec 15, 2010
- 149
Two more winterizing questions..... First Question: I live in NW Michigan and it gets cold, sometimes for a few weeks. The boat is stored unheated and covered outside or maybe inside. The boat has 2 outboards: 1989 Mercury 100 with oil injection and 2010 Mercury 9.9 4-stroke. I've read all the winterizing threads (they were very helpful) and concluded that adding Stabil and replacing the bottom unit lube is about all I need to do. My question is, do I need to do anything special to assure all water drains out of the 9.9 4-stroke? I'm comfortable just tipping the 100 hp down and allowing it to drain. Is that all I need to do for the 9.9....just tip it down and allow it to drain? Second Question: My winterizing plan for batteries is to charge them fully, then disconnect and let them sit in the boat. Is that OK or should I store them in the garage? Any other suggestions?
