Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
fuel tank/anti siphon valve
  • fuel tank/anti siphon valve
    read some postings re: sticking anti-siphon valves on fuel tanks causing rough running motor at low rmp's ...Do all fuel tanks have anti-siphon valves?Where do I locate the valve?is removal acceptable/are there any hazards associated with removal?The fuel tank fill/gas cap fitting on my center console boat is in a recessed black box with a fill cap and a vent. (brand name is Attwood) Looking inside the console I can see the vent hose and the large fuel hose heading towards the tank. I checked the vent and it looks clear. I don't see anything that appears to be an anti syphon valve - just a the black hose material on both the vent and main fuel filling line. Is the valve inside the hose itself? Wanted to check or remove to help eliminate a rough idle I'm having.
    Re: fuel tank/anti siphon valve
    the valve is located in the fuel tank fitting. If I might suggest it, why not get a different portable 6 Gallon tank and try that first to eliminate the fuel tank as the cause of your problems. Only $20.00 or so at Walmart.
    Rick
    "Boating is Life...All the rest is just Details"
    2007 Bentley 200 Cruise
    2007 Merc. 90 4 stroke
    • #3
      I second Admiral Rick's suggestion.....having been there... done that.....Location of the valve....On my boat it was located at an 'L' shaped brass fitting in the fuel line first coming out of the tank.....it screws into the 'L' shaped brass fitting and the fuel line hose connects to it
      • #4
        Good idea on the portable tank - hose is hard wired so to speak into the motor - i guess i can detach/attach at the fuel bulb. The more i think about this - wouldn't a bad valve give a constant starving fuel problem? Mine is more intermittent and rough idle usuall after getting warmed up. Trying to eliminate all simplest things first. Thanks for the info
        • #5
          If it runs good at all other times, save your money and forget the anti-siphon valve. Post a new topic on your problem. Could just be spark plugs or carb adjustment causing the rough running.
          Rick
          • #6
            Thanks Rick - will rule that one out. So far I've replaced plugs, sync n link, decarbed, fresh fuel, checked coil grounds, don't see any obvious visible gasket leaks/fuel leaking/bad fuel line connectons/etc- checking this evening - puddle fuel check valves/tubing/Pulser coil/ignition coils/rule out or confirm CDI unit malfunction
            • #7
              have a fuel leak in my 86 70 hp evinrude it runs fine no problems with idle or anything but when boat is parked on trailer it leaks gas/oil could this just be the anti siphon valve or something else? please help the dolphin bite is hot and im docked!
