Re: Kicker steering to I/O
Those brackets work but buy the best one you can afford. Is there a "lift assist" of some kind? Some of the spring-only ones I've used were a bear to raise up and the ones that were easy to lift you almost had to stand on the kicker to make it go down. I assume those issues have been addressed by now. Do you have electric start on the kicker? It might be difficult to pull start in the full down position and I can't tell how much room you have back at the transom.
On the positive side, you will love having the two motors steer form the helm while trolling. I later added a troll control so the kicker speed can also be controlled at the helm. Very happy with it and easy to install.
15hp seems about right for that size boat. A very comfortable looking ride.
sorry grabbed the wrong pic.
ALUMINUM AUXILIARY MOTOR BRACKET FOR 4-STROKE MOTORS
MODEL NUMBERS
71090 71091 71093
Raise and lower trolling and auxiliary motors on power and sailboats with ease
Built especially for new 4 Stroke, heavier, high torque motors
Extra Wide 11 1/2" (29cm) Black Poly Mounting Board for new, wider style motor locking clamps used on late model outboard motors
Accommodates long or short shaft motors
Motor Safety Cable included for added protection
With 5 vertical running position lock bar to compensate for water surface and boat load conditions – Hard coated for added resistance to wear
New, ergonomically designed twist lock safety knobs secure bracket in place
Heavy-duty stainless steel torsion springs help counterbalance motor’s weight
Easier to hold with comfortable, soft Hypalon grip handle designed to accept most style outboard motor locks
Black satin Anodized aluminum body resists corrosion – Dubbed the “Black Beauty" Outboard Motor Bracket
2" Thick, Extra Wide Black Poly Mounting Board – Weatherable and maintenance free
Aircraft Type Stainless Steel Hardware – For increased durability with nylon friction resistant washers
MADE IN THE U.S.A.!
No electric start, but kicks on very easily. When fishing I'll have the back bench seat out so can get right to it; haven' started on boat but thinking I'll be good.
