I have a 78 Starcraft Seafarer 14ft boat with a short shaft transom. I have two motors that I use interchangeably with this boat. (1) a Mariner 9.9hp and (2) an Evinrude 25 hp. The anti-cavitation/anti-ventilation plate on the mariner sits flush with the bottom of the transom. However, on the evinrude it's approximately 1" below, thereby causing drag which I want to eliminate.
So my question is, what is the best method for jacking the evinrude up. As a cheap experiment I'm considering getting some 3/4" x 3/4" or 1"x1" square tube from home depot, as I've only got about that much space on the top end of the transom to allow the clamps to remain on the transom. The other alternative is to get one of the manual jack plates with an 5" offset.
What are you guy's opinion, what have y'all been successful with? Your thoughts and suggestions are appreciated.
