Hi. I hope I'm posting this in the right forum.
I am in the market for a used boat and some of the ones under consideration are a bit older (late 60s early 70s) and some have Sea King outboard motors. A local repair shop said I don't want to own a Sea King outboard because any major issue and might not be able to get parts.
I wanted to see if that is the consensus. After doing some searching I do see that parts might be tough to come by. I just wanted to get some thoughts from those on here whether I should in fact stay away from boats with a Sea King on them.
I suspect to replace a ~50HP motor even with a like older used 2 stroke is going to be somewhat expensive. Are the throttle and shift linkages on a Sea King in the 1970ish era interchangeable with any other brands of outboards?
Thanks!
Thanks!
