It is a 1982 Johnson 115 on a Hpv165. WOT will actually give me closer to 6000 rpm now since de carb. I only achieve the 6000 rpm through ventilation I believe. If trimmed almost full out, it ventilates and only runs at about 37 mph. If I trim slightly back in, I loose the rooster tail, it sounds like I am digging better, my rpm drop to 5500 and hit max 44 mph. It is hydraulic tilt/trim, steel 12 3/4 21 pitch prop, 4750 feet of elevation and about 60 degrees on average here this last week.
The motor is coming off for a transom replace and a restore. The motor is already mounted pretty high which is why I mentioned a jackplate. Does anyone know a good jackplate that isn't super expensive and what set back would be recommended for this boat? And since I dont have a tree big enough to act as a hoist point, can anyone tell me where to find the specs on how to build a hoist out of lumber from a home improvement store that will hold up to the weight of this motor. 320 lbs. Thanks.
View attachment 214200View attachment 214201
