Good evening. I have recently purchased a 1987 Stratos VT Rocket 200 with a same year Yamaha 200HP outboard, 21 Pitch prop, and a manual Hi Jacker jack plate. This boat has a tunnel hull. This is my first personally owned outboard rig but I have been around and used them over the years. This is however my first adjustable jack plate. I prefer cruising with this rig around 3-3500rpm which typically results in a 35-40 mph speed. This speed seems to be a fairly comfortable, economical setting and keeps the boss from whining too much. My issue is that I have to have the motor buried all the way down (IN) with the trim to keep the bow from bouncing up and down excessively at and around that speed, in smooth water. If I begin to accelerate from there and really start getting it, it does smooth out and I can trim up a bit. I think thats where the tunnel hull starts to do it's thing. Can adjusting the jack plate up or down help smooth out my bow bounce at lower speeds? I'd imagine I am losing a lot of performance with the motor trimmed all the way down (IN). Also, I do not have the option of trim tabs on this transom.
Any help or suggestions would be greatly appreciated!!
Thanks,
Jon
Thanks,
Jon
