Re: Winterize with Seafoam?
I have done as others explained, namely put Stabil into gas tanks that already contain Seafoam, and it does no harm. I will be doing that in a few weeks up here in northern Michigan. Next spring, after you've used up the gas in the tank, fill it up and put in the minimum recommended Seafoam to keep things clean. As you may be well aware, outboards differ from many other engines in many ways. First, they are run infrequently thus allowing gum to build up in fuel passages. Second, an outboard that won't run or start is not just an inconvenience when you're out on the water, and third, outboards typically sit in a very, very humid environment 24/7 so they have the opportunity to collect moisture that condenses into water in gas tanks, lines, and carburetors. Seafoam helps prevent lots of outboard problems.
