Can some please help me i cant get the oil screws out to drain the lower unit. I tapped it with a hammer and screw driver ..soaked the screws in penetrating oil and i still cant get these screws off .....PLEASE help
Impact driver
That oil would have some water in it. Looks like a very slight amount but you could have a seal problem.is it normal for the oil to look like this (it hasnt been changed in a year)View attachment 170119
Since you had removal problems........... be certain to replace the special washer that goes on the fill and drain screwsthanks im going to fill her back up...and take her out this weekend...then drain the oil again and see if it is still milky
You should be replacing those every time you change the gear oil. I buy 5 of each of them at a time for each plug so I have enough for many years.Since you had removal problems........... be certain to replace the special washer that goes on the fill and drain screws
Take a washer, or something flat that will fit into the slot and place it in a set of vise grips. This give you better turning power then a screwdriver. Hope it works. Other thing is to heat them LIGHTLY with a propane torch or heat gun.
