• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Somebody please explain what VRO is/does?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Somebody please explain what VRO is/does?
    Sorry for being an amatuer, the book is on the way!
    Re: Somebody please explain what VRO is/does?
    VRO=variable ratio oilingIt is a metering pump that controls the gasoline/oil ratio delivered to your motor (simply stated).
    ACTA NON VERBA​
    • #3
      All 2 strokes require oil to be mixed with gas for lubrication purposes. On older motors, and some newer by choice, you would mix 2 stroke oil in with your gas at a specified ratio. Modern motors use a ratio of 50 parts gas to 1 part oil.VRO takes the place of having to mix your fuel. It is a self contained oil tank that, when working properly, will mix the required amount oil with your gas without your intervention other than keeping oil in the reservoir.
      • #4
        Thanks a lot guys.I was wondering why people disconnect the VRO unit, is it unreliable or something??
        • #5
          c11yll,The VRO system is one of the most maligned mechanical devices ever conceived by man. It has been blamed for everything from sunspots to hangnails.Thruth is, most engine failures that are attributed to no or low lubrication usually effect one cylinder. These concerns are caused by clogged carb. jets, not the VRO system. The VRO systrem CANNOT discriminate which cylinders get oil and which do not. The system injects oil into the fuel BEFORE it gets to the carburetors.Have VRO systems failed-sure they have, so have water pumps and other components that can cause catastrophic failure.The VRO system typically is a hands off feature that most boat owners are unaware of the fact that the system does require maintenance.The maintenace is very basic and generally includes a thotough cleaning of the tank, replacement of the filter sock and a check of all the associated delivery lines-no big deal.I have never had a moments trouble with any of them I have owned and would have another any day.
          • #6
            Good one djohns! my sentiment exactly.
            • #7
              Very good djohns! I have seen motors with water in all 6 cylinders and the cause of failure is listed as "VRO failure". The VRO pump didn't fail.....it was pumping what was in the tank. Water.The only thing I could add is that they have not been "variable" for quite a while. They are now refered to as "oil pumps" because they are 50:1 at all rpm's.Good post djohns!
              • #8
                That's just the answer i'm looking for, my confidence has now been restored. I was thinking for a while there i might have purchased a real trouble maker, there seems to be quite a few people on this site who have/are disconnecting their vro's. With me being new to boating i was rather worried!!Thanks for taking the time to reply y'all!!
                • #9
                  My Vro just went, But I guess after 17 years thats ok.I Put a new one on without a second thought. (1985 175 Johnson)
                  • #10
                    The VRO on my 94 Evinrude 140 has just given up. A re-man replacement is only $100 from DFI. Any accessory component on anything, car, motorcycle, truck etc. is subject to failure and would cost as much. I'm keeping the VRO operational.
                    • #11
                      PS- to correct an earlier post about the "50 to 1" ratio, gas is 50 to 1 over oil. That is to say 1 gallon of oil (outboard motor oil) to 50 gallons of gasoline.
                      • #12
                        can't wait for the manual to arrive, i'm just bustin to get busy on this thing!
                        • #13
                          neptune202,And I just mixed 50 gallons of oil in a gallon of gas. I edited my typo.
                          • #14
                            For an indepth story on the misconceptions, upgrades, and history of the VRO, get a back issue of either the Jan 2000 Bass and Walleye Boats or the Feb. issue of Trailer Boats.
                            • #15
                              Double check you warning system to make sure it works. I've also seen a lot of failures because the horn did not work properly.Good luck!
