Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
S80 orM80 neon test Light. best 1? where can i get 1 on line?how much?
  • S80 orM80 neon test Light. best 1? where can i get 1 on line?how much?
    what is the difference between the two? better to have both? sparktesters? can i make my own?
    Re: S80 orM80 neon test Light. best 1? where can i get 1 on line?how much?
    Check with "Stevens Experimental" for that and other special equipment.
    Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
    • #3
      hey joe reeves, ive done several searches on stevens experimental & can only find articles on pshycology. can you attatch a url or other link that will lead to the online purchase of these items? can you tell me the difference between the s-80 & the m80 neon test light?can the tests described in my repair manual be done with other test equipment?if so,do you know of a publication that presents the procedure?
      • #4
        The neon lite by Stevens (S 80) and Merc-o-Tronic (M80) has not been recommended for over 20 years. The peak reading voltmeter or DVI is used now and is more accurate.You can buy the meters for over $100 from Stevens or Merc-o-tonic or buy the adapter for a digital meter for about $49. Several companies make them but you can order from Precision Mfg. at 800-237-5947. http://outboardparts.com/troubleshoo...eshooting3.htm is a good place to read up on ignition system troubleshooting.
        • #5
          thanks alot seahorse. my manual clymer 48-235hp 1973-1990 sent me in this direction. what manual will give me the proceedure for test done with volt meter? thanks again
          • #6
            The website in my previous post and the sheet that comes with the peak reading meters or adapters will tell you the specs that you need.
            • #7
              thank you again all of you & thanks for the url seahorse
              Back to Top
