Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
gas oil mix for 52-54 evinrude 3 hp
This topic is closed.
  • gas oil mix for 52-54 evinrude 3 hp
    just got an old evinrude 52-54 3 hp wandering if anyone knows the oil gas mix for it?
    Re: gas oil mix for 52-54 evinrude 3 hp
    Welcome to Iboats.
    Let's figure out exactly what year it is first. There should be a metal tag on the transom mount with model number. Post that, and we can tell you what year it is.
    1976 Rogers Custom Boats 18' "Bonneville" W/ Chevy 454/ Berkeley 12JC
    Care Taker of 1976 Glastron V-184 Crestflight W/ Volvo 170B/280 I.O.
    & 1969 Starcraft W/ 1956 Evinrude 7.5hp Fleetwin.
    • #3
      Howdy, raney.
      Welcome to iboats.
      A lot of people "know" the right fuel mix for that little gem. The problem is that we know different mixes.
      Here is my own experience with a Johnny JW-13, same engine in different uniform.
      Originally the instructions on the tank said to mix one half pint of 30W non-detergent motor oil per gallon. That was a 16:1 mix. Lot of smoke and bad (a matter of taste) smell, but she ran fine.
      1964: Oil made specifically for outboard engines became available. OMC published in its 1964 edition of the Johnson Service Manual that all engines made by OMC before 1964 should use a quart of outboard oil per 6 gallons of regular gas. That is a 24:1 mix.
      That rule: 24:1 using outboard oil that is now certified to meet TC-W3 standards and 87 octane regular unleaded, held up until recently when papers got published calling for the little guys to go back to 16:1 or to 20:1.
      That is what many guys will tell you. Use 16:1.
      I ran my little Johnny on 24:1 for many years and she never complained. Others have run their little JohnnyRudes for 50 years on 24:1.
      If I had your 'Rude, I would run 24:1.
      sigpic
      • #4
        tag # 3012 19959
        • #5
          Thanks for the info
          • #6
            i run my 57 at 16:1, just for the added insurance. it smokes and drips goo, but its getting plenty of lubrication!
            many men fish for years without ever knowing its not about catching one.
            • #7
              yep,
              looks like Evinrude used that same tag # for the years you posted ;
              Model--HP--- Year
              3012___3___ 1952-54
              I take it you probably already looked it up here;
              http://shop.evinrude.com/media/docum...rReference.pdf
              Like JB said, it should run just fine at 24:1 with a modern 2 stroke oil. Not exactly like there is a huge difference between mixing at 24:1 VS 20:1 and 16:1 anyways.
              • #8
                yep,
                Model--HP--- Year
                3012___3___ 1952-54
                I like premium gas @ 16:1. Seems to run smoother and more efficient.
                • #9
                  tag # 3012 19959
                  Serial Numbers 09001 to 34000 were made in 1953.
                  2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
                  2015 Yamaha FX Cruiser HO
                  1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
                  1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
                  1960 Mulray 100 Dinghy, equipped with Beaver Oars
                  1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
                  68 Outboards: 1919-2017, representing 11 manufacturers
                  Member ACBS, LBOA, AOMCI
                  • #10
                    Let's all post in a 6+ year old dead thread to tell the OP who hasn't been here in eons.
                    Closed.
                    BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
                    Please, no PM's (Private Messages) regarding boat/engine problems.
                    That is what the forums are for.
                    Only forum/moderator issues will be answered in PM's.
