wrestler20
- Feb 13, 2002
- 141
I have a 1985 2.5 seadrive that two of the magnets inside of the flywheel came loose. It appears like the epoxy just gave way. i see there is a repair kit from outboardparts.com that has little hold down clamps that are attached to the flywheel. The problem is that right where i would have to drill and tap a hole to put these in is where there are drill holes i assume were for balancing the flywheel? Is there any reliable way to re-epoxy the magnets, or would it be best to start looking for a used one? Thanks Steve
