• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Control Cable end replacement
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Control Cable end replacement
    the shifter and throttle cables for this control box do not have the fittings installed. There is just a tube and wire on the engine end. A non standard replacement box is on the engine and does have the end fittings to hook up. How do I remove these fittings and reattach them to the original box cable ends? Thanks!
    Re: Control Cable end replacement
    When I state "A non standard replacement box is on the engine" I mean that I have a non standard control box mounted on the boat and hooked up to the engine. FYI I want to put the original back on because the replacement box doesnt allow choke operation from the console. Sorry for the confusion.
    • #3
      Hey SCO,If I understand your posting, you want to replace a Brand X control with the original OMC control. If this is fact, you may need to replace the throttle and shift cables with OMC cables. I'm not sure about yours, but I installed a second throttle cable (Hot Foot) on my '76 and had to use an OMC cable.c/6Hooty
