going over the motor for the year and have a few ?s
how do i know the water pump is working on this pig?(it has no **** hole)
how do i know its charging?(put the ol volt meter on it and anything over 12 volts is good?)
how much lower unit oil should the lower unit hold? i have changed the oil but it doesnt seem to hold more then 1/2 a quart
and what is the proper sized batt as far as cold cranking amps go for the johnson?
thanks for any and all replies
