Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How to properly install a outboard
  • How to properly install a outboard
    I'm coming to the point where I need to install my new rebuilt/restored outboard and I am trying to figure out how to determine the correct height for the installation. Here is the pic of my question.
    Click image for larger version
Name:	transom height.jpg
    What is the "X" height that it needs.
    The motor is a 1987 225hp Evinrude. The boat is a 1991 Bayliner Trophy. Boat transom height is made for a 25" shaft motor. The motor is a 20# but with a 5" Bay Mfg Extension kit making it a 25" motor. SO all this is good.
    Just need to to figure out what the fine measurement is at the bottom of the hull.
    J Bisson
    ___________________________
    1991 Bayliner Trophy 2002 W/A
    Past Projects
    http://forums.iboats.com/showthread.php?t=521563http://forums.iboats.com/showthread.php?t=443915
    http://forums.iboats.com/showthread.php?t=457212
    Past Boats
    1971 Starcraft Chieftan 21
    1981 Lund Utility
    1961 Evinrude Tri-Hull
    Re: How to properly install a outboard
    There is no answer for you. The truth is, any combination of boat, motor, and propeller will have a different optimum height. Get a jackplate so you can fine tune it after testing.
    • #3
      jk;
      The reccomended cav plate position to begin with is per this:
      http://www.boatmotors.com/ref/shaft_length.html
      Have you determined that you actually have a cav plate that is lower than the bottom of the transom and if so by how much? I wouldn't be sweating a jackplate at this point until you have determined that X value.
      Sometimes if you are trying to fine tune it for a small amount, some people use a small shim on top of the transom, using the slots in the clamp bracket to allow the engine to come up a bit.
      If you haven't hung it yet, measuring the transom and the distance between the top of the transom bracket and the cav plate should give you a pretty close idea of what X will be on installation.
      Not trying to counter 1979checkmate but I am just not a fan of jackplates unless there is a real need.
      Gerry
      • #4
        The main reason i suggested a jackplate is i come from a performance boating background, now with a bayliner trophy, i do imagine the OP's main concern is not speed. However, having the optimum height does help economy a bit in most cases as well. Also, my main reason for running jackplates is actually not the adjustability in height (mine always stays at the same spot), it is for the setback. At least on my boat and other performance hulls, the setback makes a HUGE difference in handling.
        • #5
          J K I'm not an expert on this, most of the info I have seen on this site calls for the starting point to be cavitation plate about 1" above bottom of hull. Fine tune from there.
          Nice job on the boat by the way.
          1973 Starcraft 21 Mariner ---------------- 1966 Lone Star Medallion II --------------- 1963 14' Lone Star Big Fisherman
          A Smart Phone is one that is Not in your hand when driving!
          • #6
            Thanks Guys for all the help with this. I'll start with even if I can. Depends on the height of the transom and the true length of the drive/mid section. I have not started playing with the measurements yet. As the boat is at a buddies house and I still need to purchase the extention kit. The kit will be ordered tomorrow and when it comes in I'll get everyhting assembled and then we start playing with this issue.
            Just wantes to get an understanding of how all this works.
            I would think you would want to be 1" on the x dimension. That way the hull would not cause any cavitation into the prop at any speeds. Is this true?
            The hull has trim tabs so adding the jack plate is not needed.
            J Bisson
            Past Projects
            Past Boats
            1981 Lund Utility
            • #7
              j_k;
              I am not an expert either but my own experience is to start with the plate just even with the lowest transom point and accounts for many of the variables with hull bottoms. This at least ensures that I have the best chance of a prop not coming out of the water in a turn as a result of the engine being too high.
              However 64osby is correct that many start out with it set high.
              I refer you to these articles which may assist you. If, when you get the extension kit and have a trial fit on the transom and are close to the position you feel is best, I would get it on the water and see what is happening.
              http://outboard-boat.com/index.php?o...layout=default
              Gerry
              • #8
                My only problem is that the "testing method" is a bit danting to me. Hell I have a 225 hp motor on a 21 trophy. That could most likely get 45+ mph. It's not really safe in my opinion to be doing high speed turns in it of 3/4 throtle. 30mph...... I'll go with the 1/2" to 3/4" like the recommend and call it a day.
                J Bisson
                Past Projects
                Past Boats
                1981 Lund Utility
                • #9
                  Shoot dhadley a PM and ask him. I consider him the Pro in the X factor area
                  This is a great link to boat specifications http://boatspecs.iboats.com/
                  Please, shop iboats first!!
                  Back to Top
