Chrysler 70 HP 1970 with steering shaft in transom bracket
tnstreamy
The previous pontoon boat owner has a hillbilly bracket for the steering cable to attach too. The transom bracket has the shaft tube where you can slide the end of the cable through and screw it too the shaft then what length steering bar/rod do I need? I see alot of Yamaha/Evinrude/Johnson/Mercs and universal type rods is the length specific due to turn radius or can any "S" bar work????:confused:
thx
Frank Acampora
Re: Chrysler 70 HP 1970 with steering shaft in transom bracket
Most of the bars will work, but some need a little modification. Some will hit the lower pan when the engine is tilted and you may need a longer screw and a spacer underneath the pan nose.
tnstreamy
thanks that's what I figured .
I'm not understanding "pan" but I understand the tilt point thanks for the input.
Just have to buy and try...
