Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Oil/water mix dripping from between prop and housing
  • Oil/water mix dripping from between prop and housing
    What appears to be a water and oil mix, drips down from between prop and housing, after a few minutes of running. I have replaced the prop seal, ran motor, but it did not solve the problem. I own a 15 hp 1991 evenrude. I'm told by a dealer I can run engine as long as the lower unit has clear gear oil in it. A repair shop said they feel it's some kind of winter storage condensation and won't harm engine when running and that it will dissapate. I am going on a long fishing trip and don't want to find out that this was bad information.
    Re: Oil/water mix dripping from between prop and housing
    I had this problem with my old force 85hp, turns out it was caused by unburned oil, only happen when I ran the engine at low speeds for a logn time ( trolling or just ideling)
    Back to Top
