Mark42
- Oct 8, 2003
- 9,334
How do you think a late model 2 stroke Yamaha 70 hp outboard would perform on my 16' Bayliner cuddy/hard top in place of the 1985 85 hp Force that is on it now?
Thinking of getting a newer motor, and knowing that the hp ratings were different between the 1985 year Force and newer model motors, I'm wondering if the new 70 hp motor would be equal to my aging Force. The Force has 110 psi on all cylinders (iirc). A little low, but even.
I like the 3 cylinder Yamaha motor because it weighs less than many similar size motors by Johnson/Evinrude (like the 90 hp models).
I don't really care if I loose 5-7 mph top speed as my intent is to get a newer motor that will be more reliable, parts are easier to get, has power tilt/trim, and is not smokey at no wake speeds.
Suggestions for light weight 70-90 hp late model o/b's, say 1990-2007, that you think would make a good replacement are appreciated.
Thanks!
Thanks!
