Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
what are the advantages and disadvantages of hydrofoils
  • what are the advantages and disadvantages of hydrofoils
    what are the advantages and disadvantages on hydrofoils
    Re: what are the advantages and disadvantages of hydrofoils
    Do a search. It has been answered many times. This question just gets everybody mad. Its either love them or hate them.
    2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
    2015 Yamaha FX Cruiser HO
    1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
    1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
    1960 Mulray 100 Dinghy, equipped with Beaver Oars
    1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
    68 Outboards: 1919-2017, representing 11 manufacturers
    Member ACBS, LBOA, AOMCI
    • #3
      Just keep in mind a fin is only a tool. Nothing more - nothing less. Like any tool, used properly the job will be easier. Used improperly, you'll be better off without it.
      • #4
        There are certain topics that for some reason some people on this board treat as if it were a matter of life and death (maybe I'm exaggerating a little). Hydrofoils are one of them.
        Having said that, they will supposedly help the boat to come on plane faster as a pro.
        They reduce the top speed of the boat as a con.
        I have one on my boat, but I didn't put it there. Maybe this year I'll take it off ans see if I notice a difference.
        Most people are going to do whatever they want. What I find entertaining is how people justify what they do!!
        • #5
          Read this again.
          And when in doubt, read it again, and again, and again.
          • #6
            People see all sorts of "do-dads" for their boat and assume adding one turns it into a go fast boat or perhaps uses 1/2 the gas it normally does. Many of those accessories, foils especially, are marketed to solve or partially solve a problem with the boat. So unless the boat has a problem the only advantage of a foil is to the seller. He has your money and you have no improvement or a worse handling boat than you had before. IF there is an issue with your boat, trim tabs are a far better solution and they won't break off the AV plate on the motor.
            • #7
              I have owned many many boats over the years and I have installed these on 2 of them. I bought the first one and the second was given to me.
              Neither time did I notice anything at all. no faster planing, no better fuel economy, and no reduced top speed. Nothing at all. So i no longer use them.
              That is just my own personal experience.
              • #8
                I have used Boston Whaler 16/17s both with and without hydrafoils. My hydrafoils were all SE Sport 300s, so I can't tell you what others would do.
                One boat had a Merc 90, the others had a JohnnyRude 70 and a Suzuki DF70.
                Compared to performance without the foil, the performance with foil was as follows:
                Plane at about 15mph vs 20mph. Get on plane noticably faster.
                No change, none, in top speed. Would cruise at 30mph at about 4500rpm vs 4900rpm.
                Know it all onlookers often told me that the foil would slow the boat down and decrease fuel mileage.
                Optimizing rig was different than optimized without the foil. AV plate was abut 3/4" higher, optimum prop on the Suzuki went from 17" to 18".
                The Whaler with the Suzuki had a 4" setback plate. The 375# engine made the advantages of the foil very important.
                The only real disadvantage I found was the harrassment by KIAs who insisted that none of the advantages existed.
                sigpic
                • #9
                  Uggghhh. The answers have all been well known, and now somebody comes along with data and confounds the whole topic. ()
                  • #10
                    Sort of like going to the doctor when there is nothing wrong with you. He can't fix what ain't broke. Same goes for foils. If there isn't an issue, you don't need one. Installing one anyway can create issues where there weren't any.
