• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Should I bore only one cylinder?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Should I bore only one cylinder?
    I have a two cylinder with one burnt piston and cylinder wall. I am being told to replace one piston with an oversize after Boring the one cylinder wall to .020 over (Hopefully that is all that will be required). I am being told since the other cylinder wall and piston look fine to leave it alone and only replace the rings and maybe hone lightly the other cylinder wall. Does this sound right? Certainly not what I am accutomed to with cars motors. I still do not know why this one burnt. Carbon on piston indicating good fuel and oil. Burnt on exhaust side the top and side of piston. This was the lower piston on my two cylinder.
    Re: Should I bore only one cylinder?
    get a second opinion on it, whoever is telling you not to bore a second one may be right, but from what i'vebeen taught to do to "small engines"... i have been taught to bore all the cylinders for simply the life of them..
    • #3
      OK. The cylinder LOOKS fine but how does it measure? Yes, it's OK to bore one but I would bet that for the minimal cost of boring and one piston you want to go that way. You need new rings for the other cylinder after you hone it anyway. Have you figured out what caused the failure?Good luck!
      • #4
        We can not find any obvious cause for the failure. I was not on the boat when it occurred. It was "loaned" out. I don't know if it was overreved, it does not appear to have been lean, any thoughts?
        • #5
          Sandman... You don't say what engine you have. If your engine has more than one carburetor, more than likely your engine failure was due to the lower carburetor becoming fouled, resulting in an improper mixture (the carbon build up on the piston does not indicate a proper mixture). Always rebuild all carbs when rebuilding an engine, and make sure the ignition is perfect.Now, if you have damage on only one piston/cyl, and the other(s) are fine, do not go to the expense of boring a perfectly good cylinder and the added expense of another oversized piston. If your engine was a V/6 with damage to one (1) cyl/piston, would you bore the other five cyls and go to the expense of purchasing five (5) more oversize pistons? (not likely... or needed)! The difference in weight is about zilch and will cause no off balance problems. The bigger bore on one cyl is of no consequence as the bigger piston will in effect have the compression equal/even out with the standard piston. Good Luck.....
          Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
          • #6
            Yes, because you are 90% there. I would do them both. It will also increase HP (more bore/stroke=more HP),even if only a small amount.And you will keep the original ballance of the crankshaft intact.
            "Did you hear about the guy whose whole left side was cut off? He's all
            right now."
            • #7
              Find the cause. The damaged piston is a result -- not the cause. If you don't you are setting yourself up for a repeat failure. Old fuel, wrong plugs, dirty carb, double firing pack -- something caused the piston to "burn". Good luck!
              • #8
                I agree, something caused this but we have been unable to determine why. Are there suggestions or steps to follow that may help us to rule out things as we go along? The manual helps us in repairs but I do not see much help in trouble shooting. Can you suggest steps in determining what went wrong?
                • #9
                  Howdy, Sandman.I agree with those above. Whatever caused your problem is probably still there. Your carburetion system is a strong suspect. Be sure to fix the cause before running the engine again.Overboring one jug is a sure way to unbalance your engine. BAD news. Don't even consider it.Red sky at night. . .JB
                  sigpic
                  • #10
                    Hey Sandman here comes my two cents worth. I agree with Joe Reeves, I've overhauled a lot of outboards; it don't make any differance. As far as hopping it up, I don't think that you will notice any differance. One of the reasons that you can get away with boreing just 1,2,or ever how many is that each cyl. is a little engine in itself, and fires each time that the piston approches top dead center. A 4 stroke fires ever other time the piston aspproches TDC and all cyl.s interact with each other through a common crankcase. I have just completed a 90 HP that 2 cyl.s have been bored to .064" one at .020" and one at .044". I don't think that I would do my own quite so radical, but this is a rental engine and the owner just wants to get it back in service. I know that some people might dissagree, but that's what I've always been taught, I have never had any trouble with it.
                    • #11
                      Only 2 cyl.
                      • #12
                        Yes, it is a Johnson 1990 40HP 2 cylinder.
                        • #13
                          Hi, Joe and ARA.I don't know where you guys learned your physics.A two, three, or any number of cylinder engine is ONE engine, not a bunch of little independent engines that don't affect one another or contribute complimentary and opposing forces to the whole. The same is true of the reciprocating masses in that engine. A +.030 piston weighs more than a stock piston. If you have one of each you have imbalance.Your crank, seals, etc. may tolerate an imbalance. . . for a while. That doesn't make it a correct thing to do, but if it's your engine, take whatever chances you wish. If it's someone else's engine, that is a different matter.Red sky at night. . .JB
                          sigpic
                          • #14
                            Just a thought -- Wiseco has made sure their oversize piston assemblys are within weight tolerence of standard pistons. That's why you can run different oversize pistons in a two cycle outboard motor. Go by cylinder measurements rather than weight. I still think you will end up boring both anyway. By the way -- did we figure out what caused the failure?
                            • #15
                              I completely agree with joe and almost retired, it won't hurt anything to just bore one cylinder, I have done it hundreds of times and never had a problem. Balance in a 2 stroke is not nearly as important as it is in a 4 stroke, unless your racing or turning the engine 9000 RPMs. In fact when johnson built the first 3 cylinder everybody told them it would never last because it wasn't balanced but look at them now, they are a very popular engine for reliablilty.
