Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
wings on your outboards????
  • wings on your outboards????
    What is the correct name for those wings that people bolt to the cavitation plate and does it really help a tired outboard get up on plane?
    cheers
    Re: wings on your outboards????
    The generic term is hydrofoil.
    "Winter Dream"
    Silverton 34C
    White/Green
    Wellcraft 23 Nova XL
    Lowe 1448 BigJon
    w/Evinrude 25HP
    • #3
      Why do people put hydrofoils on their outboards????
      no subject
      • #4
        Re: Why do people put hydrofoils on there outboards????
        Good marketing.
        • #5
          They will help to lift the boat when over-propped or under-powered. - They also provide substantial drag.
          • #6
            Two threads, same subject. I merged them.
            2002 20' Hydra-Sports 202DC 200HP Yamaha HPDI
            1976 18' Starcraft SuperSport 90HP Evinrude
            Restoration thread http://forums.iboats.com/showthread.php?t=357767
            • #7
              to cover up a broken anti-cavitation plate
              • #8
                Mudlake has posted before, I think its legit.
                sigpicSignature- If you have fuel and spark- Have you checked compression?
                • #9
                  When properly rigged, a hydrofoil, attached to the anti-ventilation plate.
                  Lowers planing speed, regardless of prop or power.
                  All of the negative myths about hydrofoils are supported by examples of being badly rigged.
                  sigpic
                  • #10
                    And most, if not all, of the marketing is supported by a paucity of independent, empirical data.
                    • #11
                      These things have been discussed to death in these forums. Those who favor them amount to about 1% of those who have actually used them. Look at it this way, if they provided any significant benefit the manufacturers would have designed the AV plate that way.
                      • #12
                        this is what I really wanted to here.
                        Never had big enough motor to put one on and didn't know if they worked.
                        thanks
                        • #13
                          Bad news.
                          1)I am a firm believer that if there was a really good reason for it the engineers would have built it into it. Especially after all these years and different manufacturers.
                          2)Bushing and bearing killers. 2 friends of mine had the same outdrive, same year and almost identical hours. Only difference, 1 had a hydrofoil and his pivot bushing/bearings went bad at about 200hrs.
                          They do help keep the bow down. If you do a lot of skiing with a boat not purposed for skiing it may be something you want to consider. If not, Iíd skip it.
                          Current
                          1988 Fisher SV-18GT Bass Boat
                          * 1988 Evinrude 90hp VRO
                          1982 DuraNautic 14' Offshore
                          1983 12' Lowe row boat
                          Various Antique Outboards
                          Past
                          1996 Larson 226 LXI bowrider
                          * 5.7 FI Volvo Penta with SX drive
                          1987 Chapparal 187 bowrider
                          * 5.0 Mercuriser with Alpha 1 drive
                          • #14
                            I put a home made set on a 9.9 merc I have because I was running it on a boat with a 21" transom and the motor was a short shaft. I had only the one motor then and it was not very deep in the water. At a slow creep it was fine but once it got moving it would suck air. With the rig on the motor it would keep more water on the prop. It didn't take the place of a long shaft motor but I was able to use the boat.
                            • #15
                              So that entire subject doesn't need to be typed out again here's a link to a recent thread on the same topic. In your application it may help to get you on plane if used incorrectly, but its not what you need.
                              http://forums.iboats.com/showthread....highlight=foil
                              Back to Top
