Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
difference between seafoam and carb cleaning
  • difference between seafoam and carb cleaning
    i was wondering what the difference between seafoam and cleaning your carb is.
    Re: difference between seafoam and carb cleaning
    Seafoam is not a carb cleaner. It can be used to de-carbonize the cylinders.
    Many will say that running it in with gas will clean your carb but I have never found that to be the case(boats and motorcycles).
    For 3 dollars you can get a can of spray carb cleaner pull and clean a carb in about an hour. You will still have about 7/8ths of a can of cleaner when you are done. Seafoam is about $8 here and you use the whole bottle doing nothing.
    Boat fixer for FSU rowing
    http://fsucrew.org
    • #3
      If I have a really nasty carb I always used Berryman's Chem Tool in either the spray or the liquid. Really bad stuff and paint hates it, so do your hands, makes them crack with no natural oil left.
      I think if you have a varnished carb, SF will do nothing for you. I have restored what I thought to be beyond use equipment, especially 2 cycle with it, but none of the "been sitting 2 years" stuff. Worked great for what I use it for, but I used a lot more than the recommendations on the can, initially. Never did/had to do the "decarb" procedure you will find on here in the archives section.
      Worst thing in SF is Naptha (paint thinner per se). Worse thing in Berryman's is like Acetone, or MEK or bad stuff that really attacks crud.
      HTH
      Mark
      If you are new to boating or have a new boat, a knowledgeable friend could show you how to operate your boat and save you a lot of grief, maybe some money, and maybe your life.
      • #4
        No chemical cleaner can take the place of actually cleaning the carb by hand.
        You have to pull the jets and run a copper wire through them to get them really clean, chemicals will break things loose and usually clog a passage.
        After cleaning a chemical cleaner will help keep it clean but to get them really clean you have to that by hand, I use Lucas gas treatment along with the new fuel line and draining the float bowls over the winter and I haven't cleaned mine in 2 years.
        Changing gas line and a filter make the biggest difference, alot of guys are running 10-20 year old engines with the original gas line, peices flake off and gum up the carbs, also letting gas sit over the winter will varnish the inside of the jets and make them run bad.
        GO IRISH!!!!
        • #5
          seafoam, added to the fuel, keeps a clean carb clean, nothing will clean a 2 stroke carb, except dismantling, and cleaning it, new carb kit.
          FLORIDA GATORS
          TEBOW Country
          Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
          That is what these forums are for. Post your questions, in the appropriate Forum.
          • #6
            If you suspect a carb problem take it apart,soak it in carb cleaner and clean and blow everything out.Otherwise you're just beating a dead horse...
            If you can read this thank a teacher.If you can read it in english THANK A VETERAN
            • #7
              i have a 2007 honda 2hp 4 stroke. would adding seafoam to its fuel make a difference? i dont really suspect anything is wrong.
              when you say changing the original gas line do you mean the line running from the tank to the motor?
              • #8
                Yes , all original gas line, normally from the tank to the engine and then there is line inside the cowl too, that alot of people forget.
                On an 07 I think you are good, I was speaking more to engines from the 80-90, mine is an 81 and I just last year changed the line under the cowl, of coarse I had changed the line from the tank to the engine btu never thought about under the hood.
                GO IRISH!!!!
                • #9
                  2007 would already have new lines.
                  FLORIDA GATORS
                  TEBOW Country
                  • #10
                    allright
                    thanks!
