water pressure gauge on outboard?
smsean
trying to figure out if I should get a water pressure gauge for my outboard.Is it a good thing or not? :rolleyes:
D
DJ
Guest
Re: water pressure gauge on outboard?
You betcha!! Wouldn't rig one without one.
Salty Dog
I'm putting one on my Yammie soon.
trollhole
I have a force 90 which only had a overheating buzzer on it. So if I was a full throttle I couldn't even hear it. SO I installed a water pressure guage. It has saved me many time when I have sucked mud or debris into the intakes. I would rather know I was going to have a problem before I had one so I could fix it. :mad:
Dhadley
The number one most important gauge.<br /><br />Good luck!
Cut n' Jump
Um, a water pressure gauge? Where would I hook one up to a 77 omc 70 horse and what should the pressure be? I don't know if my buzzer works. I do check water flow every once in a while though.
spinfreak
I have a 1984 150 hp Merc Blackmax, and I'm interested in installing a water pressure gauge. I've tried looking around on the internet, but can't seem to find anything about them. How would I go about getting and installing one? Does whatever I need come in a kit (gauge, wires, etc), or what? Also, would this get hooked up to the engine? <br />I'm also interested in installing a temperature gauge. Would this be hooked up the same way as the water pressure gauge?<br />~thanks~
chumbucket
Spinfreak is that carb.or injection motor
petryshyn
did you check the web page on my last post?
chumbucket
Spin got 82 150 might put pressure-temp gauge on,Trying to keep it live as long as i can 150 merc chumbaitn.j.@aol.com
smsean
thanks everybody !!! will do as soon as possible. :)
novacane
ok mr im a cheapscat is back looking at said diagram can well lets say ive got and old but good working oil presure gauge should work right?<br /> :confused: well ill let ya all known as im gona toss one on thks for the water presure info :cool: c ya p/s great forum<br />for back yard harrys like myself
jamschan
Water presure guage is a good thing, you can see quickly that you have a problem, but please beware of how you attach tube to engine. Dealer who rigged my 250 yamaha did it wrong, attached verically and tube flexed as engine vibrated. So it broke, I did not see imediately, resulted in engine inhaling a large amount of salt water, then blew. Lucky it was under warranty and yamaha made it good with new block.
sandman
My brother installed a water pressure guage on his 150 Johnson when he rebuilt it 10 years ago and used a oil pressure guage from NAPA and it and motor have worked well ever since.
