• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
water pressure gauge on outboard?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • water pressure gauge on outboard?
    trying to figure out if I should get a water pressure gauge for my outboard.Is it a good thing or not?
    Re: water pressure gauge on outboard?
    You betcha!! Wouldn't rig one without one.
    • #3
      I'm putting one on my Yammie soon.
      • #4
        I have a force 90 which only had a overheating buzzer on it. So if I was a full throttle I couldn't even hear it. SO I installed a water pressure guage. It has saved me many time when I have sucked mud or debris into the intakes. I would rather know I was going to have a problem before I had one so I could fix it.
        96 Trophy 1703 96 force 90
        • #5
          The number one most important gauge.Good luck!
          • #6
            Um, a water pressure gauge? Where would I hook one up to a 77 omc 70 horse and what should the pressure be? I don't know if my buzzer works. I do check water flow every once in a while though.
            • #7
              check this out Cut n' Jump web page
              Alias "schematic"
              • #8
                I have a 1984 150 hp Merc Blackmax, and I'm interested in installing a water pressure gauge. I've tried looking around on the internet, but can't seem to find anything about them. How would I go about getting and installing one? Does whatever I need come in a kit (gauge, wires, etc), or what? Also, would this get hooked up to the engine? I'm also interested in installing a temperature gauge. Would this be hooked up the same way as the water pressure gauge?~thanks~
                • #9
                  Spinfreak is that carb.or injection motor
                  • #10
                    Carb
                    • #11
                      Chumbucket? anybody? Any info?
                      • #12
                        did you check the web page on my last post?
                        Alias "schematic"
                        • #13
                          Spin got 82 150 might put pressure-temp gauge on,Trying to keep it live as long as i can 150 merc chumbaitn.j.@aol.com
                          • #14
                            thanks everybody !!! will do as soon as possible.
                            • #15
                              ok mr im a cheapscat is back looking at said diagram can well lets say ive got and old but good working oil presure gauge should work right? well ill let ya all known as im gona toss one on thks for the water presure info c ya p/s great forumfor back yard harrys like myself
