• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Recirculation valves on reed valve block
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Recirculation valves on reed valve block
    Which way is the flow. I ran a wire through two of them & now think I broke them. I could not get flow through them. I can't get low pressure flow into them to reed block or other end of hose into block. The choke also puts fule in block as same place 1" away.?????????????????????? Thanks for any input.
    Re: Recirculation valves on reed valve block
    What motor? Typically fluid flows from lower cylinders to upper cylinders and the check valve is (usually, but not always) the lower one.-John
    • #3
      It's the posted 100 hp evenrude runs erratic.It's e100tlcsc ser c7084348, evenrude 100hp v4 1980 from canada.It has 4 plastic, screend valves-?, one on each reed valve on the Reed valve body and the small hoses go back to same cylender at crank case.
      • #4
        Flow is from intake manifold to bypass covers. Hose routing is: #1 cylinder (on intake manifold) to # 3 cyl bypass cover (side of block), #2 (intake) to #4 bypass, #3 cyl (intake) to #1 bypass, #4 (intake) to #2 bypass. Yes, the fuel primer lines do go to the bypass covers. The check valve assemblies are all on the intake manifold (the also utilize a filter screen which could be carboned up) - you way have damaged them if these are the ones you ran the wire thru. I haven't read your other post yet, but its my next stop.-John
        • #5
          I have looked and looked but, but can't find n0.system for carbs or cylenders. would you mind telling me. Say as faceing motor or say as facing with motor?? Thanks!!!!
          • #6
            Standing behind motor, looking toward front of boat:2 - 14 - 3Sitting in boat facing the carbs:1 - 23 - 4-John
            • #7
              thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
