dukeOfluke
- Feb 12, 2002
- 3
I submitted an earlier post about gas leaking from my bottom carb when the motor is tilted up. I Got a response that this is normal but I am not talking about a little gas and why would the other two not leak? I assumed it would be some kind of stuck bowl check valve or something that would be causing this problem as it did not leak when I first purchased my boat. This problem started this summer and while I was servicing the enginne I thought I would try to fix it since it leaks through the cowling and stains my deck every time I tilt the motor up. Please help with any suggestions.
