• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Synthetic 2 stroke oil questions
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Synthetic 2 stroke oil questions
    is there any reduction in wear usinga synthetic oil?what are the benefits?and which oil is best?
    Re: Synthetic 2 stroke oil questions
    The full synthetic is great but expensive. The synthetic blend is great and more reasonably priced. I prefer Penzoil and have found it at Wal Mart and K Mart. Good luck!
    • #3
      Check out this months issue of Trailerboats Magazine. They do a full write up on the Pro's and Con's. www.trailerboats.com.
      • #4
        I checked out the trailerboats.com and did not see any mention of the pro's and con's on oil.
        • #5
          Interesting that you should bring this up, Len.We haven't had a fight about oil all week. Have you read the article on oil types in the Engie FAQ Section?Have you done a search for threads about synthetic oils?Try those out. Good luck.
          sigpic
          • #6
            Len:In a word, YES. Ive been able to tear several small engines apart over the years that were run on synthetics. they generally look like new inside, even after being abused. They still have the hone marks in the cylinders and are clean as a whistle inside, rings are free and very little carbon buildup if any.
            • #7
              i used shell 100% synthetic 2 stroke oil in my outboards and i use synthetic lower unit lube too. i was skeptic, thought id try it at least once and see what happens...i ran through a full 6 gall tank mixed with 87 octane and 50:1 synthetic and my engine is noticabley quieter, smoother, and doesnt smoke as much... all of the engines i have used it on are small tillers, 3hp, 5hp, 6 hp, and 14 hp... so i dont know about big motors gaining a few hundred rpms to play with or not...it was 20 bucks a gallon for the 2 stroke and 6 dollars a quart for lower unit lube.. i wont change back to regular unless i absolutely have too..they also start easier, but i think that may have to do with the smooother running-ness of it...to shorten my story to a few words.." i love it"try it and youll see........mikey
