Hi...
I need some advise... Can I use a jack plate lower on a 20 inch transom to use a 15 inch outboard on a 20 inch transom. I have it on there and the cavitation plate is just under 4 inches from the bottom of the transom. I was wondering if i could put on on of those ajustable jack plates and use it to lower the motor> I was told to cut the transom but i reallu dnt want to do that.
Thanks for your help.
